Leave or Delete Projects
09-24-2020 07:46
Leaving Projects
If you no longer wish to be a part of a project, you can leave the project. Once you leave a project, you will not be able to rejoin unless you are invited back into the project by an active project member.
If you are the only Project Admin in the project, you cannot leave until you assign the Project Admin role to another project member.
Learn more about:
Leaving projects ›
Transferring project ownership ›
Delete a Project
Only a Project Admin in the project is allowed to delete a project forever. This delete action is executed through 2-step confirmation with a clear note that the project will not be restored once deleted.
We do not recommend deleting a project that others may have been collaborating with you on as this any data inside the project will be lost forever. If you do wish to delete, please back up the project's data before deleting the project as this cannot be undone, users will not be able to restore the project after completing this process and the project will no longer be available for all members.
Learn how to delete projects in:
Trimble Connect for Browser ›
Trimble Connect for Windows ›
03-19-2025 02:28
How do I delete or leave the project when I am a user and not the owner of the project. But the owner has left the project and I am the only one still left.
