Novapoint
Licensing - general and FAQ
11-08-2021 02:38
General info
From version 2020, there are now 2 installation packages to be found on the web, one called Quadri and one called Novapoint. If you are going to use the design modules in Novapoint, select the Novapoint package, which also contains Quadri.
The license file from the year 2021 contains Novapoint design modules as a floating network license for version 2020 and earlier versions. In addition, it contains Novapoint Base version 21.00 and earlier versions.
When logging in for the first time in version 2020, you will be asked about the license configuration. Here, the named user for Quadri should be selected, and floating network license for the Novapoint design modules. This is a new combination option from version 2020. The license configuration for versions 20 and 21 will be exactly as before.
Everyone who is going to use Quadri Business Premium must create a Trimble ID. Users can then be managed in the license portal.
FAQ
How can I see if a person has a Quadri Business Premium (QBP) license?
Two ways to find this information: 1) Log in at https://np.trimble.com, select My Products, and you will see what license(s) you have. 2) Log in at https://web.connect.trimble.com, from the menu at the top right corner, select My Trimble Subscription. Select My Products, and you will see what license (bundle) you have.
How can I see if a person has a Quadri Business (QB) license?
Quarantine period, how does it work?
The quarantine period of 168 hours (7 Days) is set per user, per product, per company. You cannot reassign a person to the same product or company until the quarantine period is over. You can immediately assign a person to a new product or company, in this case there is no quarantine.
If I move a person from Quadri Business to Quadri Business Premium, will there be a quarantine period?
No, the quarantine period is per user, per product, per company.
Do you need a Quadri Business Premium license to share changes to a Quadri server?
Yes.
Do you need a Quadri Business Premium license to receive changes from a Quadri server?
No, you can receive data from Quadri using Quadri Business license and the Quadri viewer for Windows product.
What license is needed to access Quadri for Windows?
A Quadri Business Premium license is needed.
What license is needed to access Quadri for Browser?
A Quadri Business or Quadri Business Premium license is needed.
What license is needed to access Connect?
A Quadri Business will give you access to Connect Business, a Quadri Business Premium license will give you access to Connect Business Premium.
Where do I grant access to named users to a project on a Quadri server, to share data using Quadri for Windows?
This needs to be done by the admin, in the Quadri Model Manager (QMM) (each company have their unique link).
Where do I grant access to named users to a project in Connect?
This needs to be done by the project admin in https://connect.trimble.com/
After Connect login, my new license seems to be ignored (recently assigned/upgraded license)?
Connect for Browser: From the menu at the top right corner, select Check for updated license
What do I do when I quit my job in the company?
Trimble Connect: All your projects should have a new administrator (a colleague, not you). Then, leave your projects, and delete your Trimble ID (from the Trimble Connect menu, select: My Trimble Subscriptions, Edit Profile, Would you like to remove your account completely?).
