Use this function to project the selected entities (line, polyline, or lwpolyline) to the 3D face triangle model available on the current drawing.
MOUS_ICO Menu: Terrain > Terrain Design > Line Projection to 3Dfaces
Command prompts for:
Select objects:
Select the lines/polylines/lwpolylines, which are to be projected to the 3D face triangle model and finish with the right button of the mouse, press 'Enter' or the key 'Return'.
Follow [Terrain/MInimum/MEan/MAximum] <Terrain>:
Erase existing lines/polylines [Yes/No] <No>:
The selected entities can be erased using the option 'Yes'. By default, selected entities will be retained (prompt option 'No'). A new 3D polyline will be created.
…. UNDO [Yes/No] <No>:
Undo option to cancel the function.
