A list of user-defined and calculated data can be performed from a separate dialog box using the function 'List Element Data'. Run the function from the following location.
MOUS_ICO Menu: Bridge Tunnel List Element DataMOUS_ICO Toolbar: Tunnel List Element Data
The dialog box 'List Element Plan Data' will pop up.
The list at the top of the dialog shows the available listing alternatives. First, select which alternative is to be displayed. Then select the left or right side of the tunnel and the desired station number interval. Select the option 'All', if all the elements along the chosen tunnel side are to be included in the listing.
Having defined the parameters, press the button 'Show'. The details will be listed in a separate dialog box 'Listing'.
