There is a separate panel for GeoSuite in Novapoint Base. This includes a number of tools that are linked to activities that are created for use in GeoSuite.This panel is not loaded by default and must be configured in Novapoint Base. This is done with an additional switch at the Target line in the shortcut.The amendment to be in at the start-up is:-e:"./Extensions/NovapointGeoSuite.Extensions.sxml"**Step by step:**- Select the Properties for the shortcut- In the "Target" - add the parameter as above after the destination path to the program file (with a space character as separator)- The shortcut will then look like:
