MOUS_ICO Menu: Bridge Edit Lock/Connect PointsMOUS_ICO Toolbar: Edit Lock/Connect Points
Command prompts for:
Select a point:
Select all the points, which are to be connected and locked. Finish with the key Return or the Right button of the mouse.
After the function has been executed, you will be asked if you want to save the new settings to the database. Opt Yes to save the changes. The points that are connected will be colored with red grips and those, which are free, will be colored with cyan grips.
Use the function Release Points to emancipate the points.
