Longitudinal Profile
04-12-2021 16:12
What
  • Use this function to present the longitudinal profile for the desired trench of the active water and sewer project.
  • It is important to know that the generated profile will show the model at the time it was generated. Use update longitudinal profile to update if the model is modified.
  • The active water and sewer project is referred to as a simple model and the trench of the model is referred as a baseline.
  • Scale in the Novapoint ribbon controls indicated to scale.
  • The drawing layout will be according to the configuration.
  • Go to the configuration, settings, and Presentation longitudinal profile... to change layer names, layer colors, line types, etc...
  • Create user-defined presentation style with Long Section Style Editor.
Where
The function can be run from the following location:
  1. Longitudinal profile
  2. Update longitudinal profile from WS model
How
  • Open the dialog Longitudinal Profile
    • Select Trench and insertion point.
    • Press Draw to draw.
  • Update - The profile can be updated if the model is modified
    • Calculate the model and run the function 'Update Longitudinal Profile from WS Model'.
Tips
Add terrain heights from lines that are offset the trace.
Note:
  • Tunnel profile lines are not available for the water and sewer project.
