Longitudinal Profile
04-12-2021 16:40
What
In this dialogue, there are the following settings for the appearance of the longitudinal profile drawing:
  • Draw Nodes: If you want the nodes drawn in the longitudinal profile drawing, this selection has to be ticked off.
  • Draw Manholes: If you want the manholes drawn in the longitudinal profile drawing, this selection has to be ticked off. You will probably not want to draw both the manholes and the nodes. This may look somewhat messy.
  • Dynamic Manhole: By marking this check box, the manholes will be drawn with the correct size according to the chosen scale.
  • Draw Manhole Markers: You will probably want to get the manhole markers drawn in the longitudinal profile drawing. If so, you must tick off for this selection.
  • Draw Children: By marking this check box, any connectors in between manholes will be drawn in the longitudinal profile drawing.
  • Draw Vertices: By marking this check box, any vertices between manholes will be drawn in the longitudinal profile drawing.
  • Draw External Stations: If a trench is situated in a designed road, marking this selection will get the stationing of the road drawn in the longitudinal profile drawing.
  • Elevation Threshold: In this selection, you set the least vertical difference there has to be between the elevations of the pipe in and the pipe out of a manhole for both levels to be drawn in the pipe table of the longitudinal profile drawing.
Where
The function is run from the following locations:
