Manhole collision analysis
04-12-2021 15:57
What
Use this function to see if manholes correspond with your criteria. This function uses a configuration file with criteria to validate a set of minimum values.
Where
You can start the function from the following location:
How
This function works the following way:
  1. Click on the function.
  2. Manhole cards dialog will pop up.
  3. Select configuration file.
  4. Select the manholes you want to check.
  5. Click enter.
  6. Now you can see if they correspond with the criteria.
