Manhole Sketch
04-12-2021 16:16
What
Use this function to draw the plan view of manholes.
  • The function generates drawing files of selected manholes.
  • Separate drawing files will be generated for each selected manhole.
Where
How
When you run the function, a dialog box Manhole Sketch will pop up. This includes a list of all manholes available in the project.
  • Select the manholes, of which drawing files are to be generated.
  • The folder location, at which drawing files are to be saved, is to be defined in the field Output directory.
  • Drawing files will be named with the manhole's names.
  • Multiple manholes can be selected using windows selection criteria (i.e., using Shift and/or Ctrl; or using the mouse).
