Quadri
Migrate from Vianova ID to Trimble ID
05-26-2021 01:50
Novapoint Infrastructure Design Suite users
Novapoint Infrastructure Design Suite version 20.00 will continue use Vianova ID as authentication for the licensing.
Before taking Novapoint 21 in to use, you will need to establish a Trimble ID and link it to your existing Vianova ID.
Click to read the instruction guide for how to migrate
If you don't have a Trimble ID yet, you can create one here:
https://np.trimble.com/TrimbleID/Create
You will then receive an e-mail to verify your Trimble ID.
Next step is to map the Trimble ID with your Vianova ID here:
https://np.trimble.com/TrimbleID/SignIn
Novapoint GO users
We are moving our authentication for the licensing from Vianova ID to Trimble ID.
For some time both sign in's will be available, but we encourage all users to establish a Trimble ID and link it to your existing Vianova ID within the coming month.
After that: Open Novapoint GO, sign out, choose Trimble ID as sign in method. Sign in with your new Trimble ID, and select "remember password".
Quadri Easy Access users
For Novapoint 20.00 projects on Easy Access you will continue to use Vianova ID as authentication for the licensing. The web page will continue to be https://www.quadridcm.com
To use Easy Access for Novapoint 21 projects, you need to sign in to this web page:
https://ea.np.trimble.com/
