Trimble Connect for Mobile 2.2 | Release Notes | October 27 2017
10-30-2017 14:40
Trimble Connect Mobile v2.2
Apple Store - https://itunes.apple.com/in/app/trimble-connect/id1076606537?mt=8
Google Play - https://play.google.com/store/apps/details?id=com.trimble.buildings.connect
New Features
  • Object Color & Transparency:
    • Object color - User can color individual/multiple selected object(s) from list of color provided. User can also reset to default color with which model is being initially loaded.
  • Object transparency - User can set transparency for individual/multiple selected object(s) using transparency slider. User can also reset to default transparency with which model is being initially loaded.
  • Layer Color & Transparency - User can set layer color/transparency from option available under layer list.
  • Layer color - User can set color for selected layer from list of color provided. User can also reset to default color for layer with which model is being initially loaded.
  • Layer Transparency - User can set transparency for selected layer. User can also reset to default transparency for layer with which model is being initially loaded.
  • Markups
    • Line Markup - User can create new (or) edit a line markup loaded from a view. User can also change color of line markup from list of colors and save it as View.
    • Arrow Markup - User can create new (or) edit a arrow markup loaded from a view. User can also change color of arrow markup from list of colors and save it as View.
    • Cloud Markup - User can create new (or) edit a cloud markup loaded from a view. User can also change color of cloud markup from list of colors and save it as View.
    • Text Markup - User can create new (or) edit a text markup loaded from a view. User can also change color of text markup from list of colors and save it as View.
  • Redlining - User can create new (or) edit a redlining markup loaded from a view. User can also save it as View.
Improvements:
  • Performance improvement
    • Faster loading of projects, Data, ToDo and views list. Loading done in background in paging manner without blocking UI so that the user can still use the app with the files that are loaded progressively.
  • UX improvements
    • Hamburger UX - Revamp of master menu screen. Hololens companion, clear cache, contact support, logout options are listed in master menu so that they are easily accessible
    • Data screen menu is also revamped so that menu is the same across pages. This will be modified in future to ease the folder navigation problems.
  • Manual Sync (Pull to refresh) - Pull to refresh is implemented in list view to enable the users for refreshing and syncing the content.
  • First time Loading indicator -A progress bar is displayed below the navigation bar to indicate the progress of data sync. When the sync completes this will get dismissed and if the sync fails in between, a red line will be shown to notify the user that the sync has not succeeded. When user performs a retry, the progress will continue from where it was last time.
Bug Fixes:
  • Object Color & transparency-Transparency is not getting updated based on the selection of object.
  • Markups-pick point of text markup is not getting displayed,when user enable orthographic projections mode
  • Markups-Line markups are not getting hidden,when user deselect the markups option
  • Markups-Markup color is not getting created with selected color option
  • Markups - Cloud markup edit flow was improper
  • Markups-starting and ending point of line markup is not getting displayed,when user enable orthographic projections mode
  • Markups-Ending point of arrow markup is not getting displayed,when user enable orthographic projections mode.
  • Initializing progress dialog displayed in projects screen after sign in.
  • Database locked in random scenarios.
  • Directory delete and create - lock violation because of using c# api.
  • Text Markup - crash when editing created text markup
  • The close button selection crash in search control in ToDo screen fixed
  • The sort functionality in ToDo screen fixed.
