MOUS_ICO Models > Select Model > Modify > Projects > Model Tab
If you click on a model in the model list and select Modify and Projects and then the Model Tab, you will get more details on the chosen model.
If you want to change the name of the model, type in a new name and click the Update button.
You can also download a number of logs to see detailed and quite technical information about the model activity. Select the relevant log in the drop-down list and click the Download button. If you select All Logs, you will get a .zip-file with all the logs connected to the selected model.
It can sometimes be interesting to count the data in the model, for example before and after a large import. Click the Count Data button to get a detailed report on how many features, tasks, users, etc. are stored in the model at the moment.
