Novapoint Terrain Library
Move Point Elevation X,Y...
04-12-2021 12:50
Use this tool to move a point elevation keeping the elevation constant and updating the attached slope arrows based on the distance.
MOUS_ICO Menu: Terrain > Elevation tools >
Move point elevation x,y…
MOUS_ICO Toolbar: Levelling tools: Move point elevation x,y…
The function can also be started by double clicking on the point elevation.
Working procedure
Start the function and the command prompts:
Select point height to move:
Select the point elevation you want to move
The command prompts:
Select new position or type world coordinates:
Select the new position with left-click on the mouse or type in coordinates.
About point elevations in Novapoint Terrain
  • Point elevations are blocks with the insertion point in the “+”-sign. The z-value for the block will always be equal to the written text.
  • The leveling tools are a set of functions working within the dwg file as well as interacting with the active terrain model. Editing and calculating point elevations must be done by using the leveling tools only. It does not work to use AutoCAD-functions like move, copy, copyclip/paste, properties, attribute editor, etc. in order to edit or manage the appearance of the point elevations
