Novapoint Noise Library
New
04-15-2021 14:55
The same dialog box can be reached via Change…, the title then is Change hard ground region instead of New hard ground region, the functionality is otherwise alike.
MOUS_ICO Menu: Noise > Hard ground regions > New…
or
MOUS_ICO Menu: Noise > Hard ground regions > Dialog box… > New region…
or
nco: Select a hard ground region
MOUS_ICO Popup menu: New
In this dialog box, you define/change a hard ground region. A hard ground region must be limited by a polygon.
Identity
Identity may consist of a random selection of letters and other characters.
Select polygon <
All dialog boxes are closed, and we get the opportunity to click a polygon in the drawing. As we click the polygon, we get back to the dialog box.
Draw polygon <
All dialog boxes are closed, and we get the opportunity to draw a polygon. By pressing <Enter> we get back to the dialog box.
OK
The dialog box is closed and the region is registered/changed.
Cancel
The dialog box is closed without the region being registered/changed.
Help
This page.
