View Entry
Trimble Penmap
Community Navigator
Back to Library
New Penmap for Windows version 11.2.0.8498
Recommend
04-22-2020 08:14
Cornelia Schmitz
We have released a new Penmap for Windows version today.
The version 11.2.0.8498 includes the following enhancements:
New features
Global coordinate of the cursor position is now shown in the lower right corner.
Old nodes are shown in black; new and changed ones in blue.
Edit
GIS Polygon
supports selection of multiple polygons, for example, to create three independent buildings in one step with identical GIS.
Edit
Split line
now works with a segment selection instead of start and end points.
Support real-time message format CMRx for base station.
New
keep attributes
check box in
GIS
dialog to take over the current attributes to a new one
New toggle button (on / off) for GNSS cursor and total station position maker next to the antenna height icon.
Enable/disable layer in the Layer manager shows/hides labels in the map.
Support of “conditional fields” for GIS attributes, for example, filter an attribute field with another.
Penmap for Windows now supports the Spectra Geospatial SP60 and SP85 receivers.
Enhancements
Diagnostic files are stored in the new subfolder: MyPenmap\LogFiles.
Edit
GIS
linear
has a new
Undo
function.
Enhanced the feature selection toggle with 1 of n features.
Coordinate systems and grid files updated to coordinate system database version 89.
Query nodes: copies the value from decimal fields without the unit chars "m",...
Base Rover workflow – save base and rover settings independently to simplify the workflow.
Setting a real-time-correction via "Radio", Penmap connects to the set receiver. Penmap queries the available channels and frequencies supported by the GNSS receiver.
Export
DXF/DWG
exports the point number and code as text if the
Export point information as text
check box is enabled in the DXF/DWG export definition.
Import DXF/DWG to background is visible in
Sidebar
Background Maps
Sidebar
Edit Layers Styles Groups
Pointstyles
is extended with a preview for symbol selection.
Stability enhancements for WMS (zoom in and out).
Edit
GIS Polygon
is now using the last selected iFeature as the default.
For line features, the opportunity to toggle between “close line” and "close area" button is back.
VRSNow NTrip Caster for New Zealand added (vrsnow.co.nz).
