Novapoint Terrain Library
New Point Elevations - Running...
04-12-2021 12:52
This function calculates the elevation for a new point elevation based on the distance from the last point and the current slope. The points can be set out running, with the previous point as a reference, until the function is terminated by pressing enter. By using different options at the command line, it is possible to:
  • Lock the elevation. The slope changes when the distance changes.
  • Change the slope value (default value is 2%)
  • Lock the distance. The next point will be at a specified distance from a reference point.
  • Specify the slope and the height and the distance from the reference point is calculated.
MOUS_ICO Menu: Terrain > Elevation tools >
New point elevations – running
MOUS_ICO Toolbar: Elevation tools > New point elevations – running
Working procedure
Entering the function, the command prompts:
Specify basepoint or [Pick Height]:
Pick a position of the basepoint in the drawing, alternatively press ´P` and select an exsisting point elevation.
When a new basepoint is chosen, the command prompts:
Enter height <0.0000>:
Type z-value, press 'Enter'
The first point elevation is now defined, by moving the cursor you will see the next point elevation and distance change in real-time, based on the set slope. The command prompts:
Specify next point [Pick height/Elevation/SLope/Distance/Height&slope]:
Pick a position for the next point elevation, or change the setting by the following
  • ´Pick height`: type ´P` - select a new point by clicking it.
  • ´Elevation`: type ´E` - locks the elevation to see how the slope changes in realtime
  • ´SLope`: type ´SL`- enter the new value for slope, press 'Enter'
  • ´Distance``: type ´D`- enter a value for distance, press 'Enter' - a circle with radius equal to selected distance appears. Point out a direction to set out a new point elevation on the circle. It is possible to snap to apparent intersections (the circle and lines in the drawing). The circle is removed by option [Remove lock] - type ´R`.
  • ´Height&slope`: type ´H`- specify new elevation, press 'Enter', then specify new slope value and press 'Enter'. A circle with a radius equal to the calculated distance appears. Point out a direction to set out a new point elevation on the circle. It is possible to snap to apparent intersections (the circle and lines in the drawing). The circle is removed by option [Remove lock] - type ´R`. Arrows point downwards onto lower heights. Press the ctrl-button to get a positive slope.
Tip:
The next point elevation is automatically set at a lower level according to the slope (slope arrow is pointing away from the reference point.) Switch direction by pressing Ctrl-button during set out - the next point elevation will then instead be placed at a higher level according to the slope.
About point elevations in Novapoint Terrain
  • Point elevations are blocks with the insertion point in the “+”-sign. The z-value for the block will always be equal to the written text.
  • It is possible to use osnap when setting out point elevations - the z-value in the specific point snapped to will show in the command prompt. To use the snapped z-value instead of typing in a value - just press 'Enter'.
  • The leveling tools are a set of functions working within the dwg file as well as interacting with the active terrain model. Editing and calculating point elevations must be done by using the leveling tools only. It does not work to use AutoCAD-functions like move, copy, copyclip/paste, properties, attribute editor, etc. in order to edit or manage the appearance of the point elevations
