This function calculates the elevation for a new point elevation based on the distance from the last point and the current slope. The points can be set out running, with the previous point as a reference, until the function is terminated by pressing enter. By using different options at any time at the command line, it is possible to:
MOUS_ICO Menu: Landscape > Terrain design >New point elevations – running…MOUS_ICO Toolbar: Elevation tools >New point elevations – running…
Entering the function, the command prompts:
Specify basepoint or [Pick Height]:
Pick a position of the basepoint in the drawing, alternatively press ´P` and select an exsisting point elevation.
When a new basepoint is chosen, the command prompts:
Enter height <0.0000>:
Type z-value, press 'Enter'
The first point elevation is now defined, by moving the cursor you will see the next point elevation and distance change in real-time, based on the set slope. The command prompts:
Specify next point [Pick height/Elevation/SLope/Distance/Height&slope]:
Pick a position for the next point elevation, or change the setting by the following
The next point elevation is automatically set at a lower level according to the slope (slope arrow is pointing away from the reference point.) Switch direction by pressing Ctrl-button during set out - the next point elevation will then instead be placed at a higher level according to the slope.
