Release date: 29.04.2021
Build model FIXED: Cut-solids could have a gap between two consecutive sections.FIXED: Inner slope surface would in some cases not follow the pavement, but followed the roadsurface.FIXED: Cases of crash when building the designmodel.FIXED: Wrong elevation of the road when alignment vertical reference is set to be related to a 1-surface not located at the CL, when there are only 1-surfaces on the inside of it, but no 0-surface. QuantitiesFIXED: Case of report with 10m interval that didn't finish.CAD FIXED: Line tasks with taskpath longer than 256 characters could crash the taskselector dialog in Alignment Design and Draw Horizontal Alignment.FIXED: Slope Surface tool crashed when there are too many subsurface layers in the sections. Now it completes with a warning about checking the results.Configuration specific issues Finland FIXED: Road templates did not have the DesignModel-type set correctly. It gave problems when using Novapoint SiteTool.
Sweden Switch Design FIXED: Drawing Setup dialog missing.
FIXED: When adding a vertex on the trench reference line the pipe geometry did not update after adding a new branch node in the same trench section.FIXED: In some cases the WS design graphics got behind other layers in the plan drawing.QUADRIFIXED: Stake out data - Connection of not Manhole type stored with reference point.<note important>Remember to change conversion rule to new "Standard" in WS Construction to update an existing model with "Stake out data" fix.</note>FIXED: Pipe attribute "PipeLength" in Explorer window - Value presented the length of the first pipe segment, not the sum of all the joined segments.EXPORTIMPROVED: LandXML export from WS model improved with better interpretation of Pipe Network network type. In some situations not all pipes were exported.FIXED: SOSI export from WS model did not to include some Connections with no pipe attached.UPDATED: Inframodel export to support 4.04-schema
