Novapoint
NOVAPOINT 2020.FP1f Release Notes
08-25-2021 07:22
Release date: 30.06.2021
General
Support for Trimble ID ver.4!
Support for AutoCAD 2022 products since NP2020.FP1d!
KNOWN ISSUES
If you get this error message in your browser, when clicking on <Sign In> in QfW Account page:
We have a workaround:
  1. Change default browser to something else ⇒ login works.
  2. Logout.
  3. Change back to your original default browser ⇒ now it works again.
NOVAPOINT ROAD
Alignment Design
FIXED: Function for External Data could in some cases get the wrong elevation for the data projected to the vertical window.
FIXED: Vertical info tool had the elevation jump with 10000m in some cases.
CAD Roundabout Intersection Tool
FIXED: Crash when picking leg based on an alignment (when alignment had vertical geometry and the Quadri project was open)
NOVAPOINT WATER AND SEWER
Quantities
FIXED: Adding extra cross sections in the WS Cross Section calculation, between main calculation intervals, created an error in some special cases related to trench breakpoints.
NOVAPOINT TUNNEL
General
FIXED: Some tunnel models failed when drawing 3D-models. This is now corrected. FIXED: Cross-section drawing. Some tunnel models had very bad performance when opening the dialog for selecting the cross-sections to draw. This is now corrected.
