Novapoint
NOVAPOINT 2020.FP1g Release Notes
08-25-2021 07:20
Release date: 25.08.2021
NOVAPOINT WATER AND SEWER
Quadri
FIXED: Pipes in neighbor trench sections with same properties, start/end point, and not connected to a manhole, got incorrect PipeDeltaZ and PipeGradient value in the generic property list.
FIXED: When rebuilding trenches in WS, existing manhole features in Quadri were deleted and new instances created. Thus, values set/changed in property sets and other properties on a manhole were deleted.
Construction
FIXED: Branch node behavior when Dynamic Trench was activated (zig-zag pipes if breakpoints existed)
NOVAPOINT ROAD
Road Description
FIXED/ENHANCEMENT: Illigal characters used in road surface description will now be cleared, improving PARAM import/export.
Build model
FIXED: When combining Embankment Ditch with Softspot removal the fillslope didn't stop at terrain. It also caused a message about insufficient terrain.
FIXED: Rockcut surface with shelfs that has a downward direction caused issues.
CAD
FIXED: Vertical info tool had issues in some cases.
NOVAPOINT RAILWAY
These are the changes done in addition to what has been done for Novapoint Road.
Draw Longitudinal Profil
FIXED: Elevation on 'External lines' was wrong in some cases.
NOVAPOINT TUNNEL
General
FIXED: Sometimes, when opening the LandXML export dialog inside the Tunnel Design dialog, the wait-icon disappeared before the LandXML export dialog appeared. This allowed the user to try opening the export dialog again e.g. which again resulted in errors. This is now fixed.
