Release date: 01.11.2022
For release notes related to Quadri for Windows go here.
REVERTED: 'Propose segmentation' is now also available for alignments that are already OK.
FIXED: Import of LandXML with multiple alignments didn't show the full name when longer than 24 characters.
NEW: Sorting option for the pavement templates. This will help with sorting the list of pavement templates and to organize them.
FIXED: Renaming the last pavement template could set all thicknesses as 'inherit' in some situations.
FIXED: There were no difference between using ABS or REL references.
IMPROVED: Faster calculation in certain situations with overlapping sections.
FIXED: Cases of crashing roadmodel.
IMPROVED: Drawing style “Dralin-3DInfo” for alignments was introduced in NP2022.6. Now it is improved and also draws the alignment as a 3D polyline.
NEW: Draw Cross-sections with titlebox now supports possibility to add additional file with block attributes.
The block attributes supports adding dynamic information based on
These changes are in addition to what we find for road design.
FIXED: CANT offset was not applied when reading data from LandXML.
FIXED: Volume report could be wrong in certain situations when using KM-stationing.
FIXED: Structurelayers could have wrong results in the cross-section, in some situations.
FIXED: The vertical breakpoint could be missing in certain situations for drawing styles that uses this element type.
FIXED: Switch dialog was missing the parameter bitmap.
FIXED: Kommune numbers that were wrong.
The program has been updated with support for a number of the new signs launched by the Finnish Road Administration 01.06.2020 and updated in 2021 and 2022. The new version of the sign program can for a transitional period run in parallel with the version of the program that supports the previous standard.
Added support for new signs:
F33 and F35_6 - Geometry was not correct for all sizes (#HAN-5438)
807.3a - Added support for new sign combination (#HAN-5171)807.8a - Added support for new sign combination (#HAN-5164)808.559a - Added support for new sign combination (#HAN-5184)808.561a - Added support for new sign combination (#HAN-5174)834.1a - Added support for new sign combination (#HAN-5165)834.1b - Added support for new sign combination (#HAN-5185)
General - Added support for two missing pole symbols (#HAN-5382)3DSIGN - Added support for one more standard foundation (#HAN-5506)3DSIGN - Added support for attribute type “SignFaceDirection” (#HAN-5522)
F5 - The sign was crashing when click add plate if only symbols in the sign (#HAN-5549)
General - Added support for attribute type “MilledMarking” to longitudinal markings (#HAN-5504)IFC - Updated conversion rule for IFC-export to support attribute type “MilledMarking” (#HAN-5512)
