QUADRI FOR WINDOWS
NOVAPOINT ROAD
Alignment Design
NEW: Added functionality for analysing Reference Points and creating alignment based on them. Alignment Design has inherited functionality from 'Alignment Design from Points' and can analyse points and give a suggested best-fit alignment in for both horizontal and vertical geometry.
General
ENHANCEMENT: Warning to user when the cross-sections are overlapping in tight corners.
ENHANCEMENT: Soft spot removal now possible to set the depth with millimeter accuracy.
FIXED: Cross-section calculation could crash when gathering terrain sections from Quadri.
FIXED: Error in Quantity report for Deepblasting when edges were vertical.
FIXED: Some clothoids on alignments didn't show or draw as they should.
Sight Distance Analysis
FIXED: User-defined sight distance analysis with all adjustment-values at 0 gave 1m sight distance.
FIXED: Road standard method got reverted to User-defined or picked the wrong road standard when re-entering the dialog.
Slope Surface
REVERTED: Quantity table in Excel is back. Values are now rounded. For exact values we recommend using the volume tool in Quadri.
CHANGED: Raise/Lower function is now only available for “Lower” method.
FIXED: The function didn't always update the data in Quadri, but produced new duplicate results.
FIXED: Objectname was not read by the function for ACAD2021 and newer.
Finnish version
FIXED: Cross-section calculation would fail when producing error-messages for computers using specific Windows Regional Settings.
Swedish version
FIXED: Issue of crashing Quantity report when using Swedish report language.
NOVAPOINT RAILWAY
FIXED: Alignment Design Refpoints did not store the MIN and MAX DZ values.
FIXED: Alignment report would crash if used multiple times in a row when used in Civil 3D software.
NOVAPOINT WATER AND SEWER
Construction
ENHANCEMENT: Taper is now set to “Undefined” if the height is 0. This will improve the input for drawing manhole as 3D (SOLID) to DWG.
Cross Section Calculation
FIXED: Calculation crashed if end station value was less than the total length of the trench. (Bug introduced in NP2022 release).
Product Library
FIXED: Updated download links
NOVAPOINT ROAD SIGN
General
ENHANCEMENT : The background color used in the Main Dialogue is changed to prevent symbols from visually disappearing from the dialogue (#HAN-4426)
Finnish Version
NEW: The program has been updated with support for a number of the new signs launched by the Finnish Road Administration 01.06.2020 and 1.6.2021. The new version of the sign program can for a transitional period run in parallel with the version of the program that supports the previous standard.
ENHANCEMENT: General - Updated spacing between characters according to rev. “PVM 1.6.2021”
ENHANCEMENT: General - Added support for more reference symbols on the reference line
ENHANCEMENT: Dimensioning - Added a command to the toolbar that support basic dimensioning of signs
ENHANCEMENT: F2.1 and Yleinen - Added support for black backgound
ENHANCEMENT: F18.x - Added support for yellow background color
ENHANCEMENT: H24 - Added support for more rows and TH
FIXED: E13.2 - The size for P and N was not correct
FIXED: F2.1 and F2.2 - The horizontal alignment of TEXT in the same plate was not always correct
FIXED: F13 - The length of the sign was not correct in combination with MINI and SERVICE
Norwegian Version
ENHANCEMENT: General - A few 2D pole symbols added matching the grafical standard for “Bymiljøetaten Oslo kommune”
FIXED: 731 - The sign 776 was missing as mini-symbol for this sign
Swedish version
FIXED: F8-1 - There was a broblem with the border on service when combined with road number on white background
NOVAPOINT ROAD MARKING
Norwegian Version
ENHANCEMENT: 1054 - Add support
FIXED: Store to Quadri, Some propertie values was not stored
Swedish version
FIXED: M19a - Part of the geometry was not according to the standard
