Novapoint
NOVAPOINT 2023 Release Notes
12-22-2022 06:04
Release date: 22.12.2022
Quadri for Windows & Novapoint works with Windows 11
QUADRI FOR WINDOWS
NOVAPOINT CAD TOOLS
Swedish Config
REMOVED: Functionality for PXY-export is removed. Use 'Setting Out from Drawing' function instead.
NOVAPOINT ROAD
NEW: Expanded capabilities in Pavement description to add materials and detailed material description.
To start using the new functionality you will need to upgrade the task version 2.1 for your Road task.
See video for more details.
nproad_layer_properties
Road task
NEW: Possible to set User-Defined road standard and use User-Defined typical cross-sections.
  • Easier to see on the task that you are using a user-defined standard and typical cross-section.
  • Possibility to combine this with crossfall and widening calculations of any installed roadstandard.
ENHANCEMENT: For taskversion 2.1, roadmodel outer boundary are put on the DataDelimitation feature.
ENHANCEMENT: Sight analysis and imported road models through “From Existing Model” didn't get the correct PHASE (planned/existing).
Other fixes
FIXED: Deleting a pavement template would make a mess in the list of pavement templates.
FIXED: Softspot removal with fixed depth would excavate too much in some cases.
FIXED: Issues where SubgradeSurface was missing in some areas.
FIXED: When only adding a TitleBox AttributeDefinitions file it would crash.
FIXED: Vehicle Tracking with a box-trailer could get strange results with “Fixed angle” and “2 point start-end” methods.
NOVAPOINT WATER AND SEWER
Quadri - Utility
  • NEW: Added properties for Connection (Bend) properties
    • ConnectionAngle
    • ConnectionDimension
    • ConnectionMaterial
    • ConnectionElevationZ
  • NEW: Added property PipeLength3D to genPropList for Pipes
  • NEW: Added properties to Manhole parts (SOLID)
  • NEW: ConversionRuleEditor-possible to concatenate properties
Configuration
  • NEW: Added new setting for enabling “PipeHeightDiffInManholes”
  • FIXED: CS preview present double value of Class/SDR for Pipes
Construction
  • FIXED: Pipe slope gradient in start/end in the vertical graphic was shown as 0 if the pipe vertex closest to the pipe start- or end point was a vertical vertex.
  • FIXED: Function “Change to line” caused disconnection of pipes from manholes.
NOVAPOINT TUNNEL
FIXED: When showing and calculating scanner data, the rail height for the vertical location of the reference line given in the Railway module is now taken into account.
NOVAPOINT ROAD SIGN
Danish Version
New
In this version, we are now launching support for creating sign layouts in 3D, also in the Danish version.
Finnish Version
The program has been updated with support for a number of the new signs launched by the Finnish Road Administration 01.06.2020 and updated in 2021 and 2022. The new version of the sign program can for a transitional period run in parallel with the version of the program that supports the previous standard.
Added support for new signs: - F1.1 (colorfield on arrows now supported) - F4.1_2 - F7.1_15 - F7.1_16
Enhancements
General - New RSFIN added to ribbon menu and old moved to toolbar (#HAN-5618)
F1.1 - Added support for colorfield on the arrows (#HAN-5608)
Fixed
F2.x - Used a wrong vertical distance from colorfield to border (#HAN-5691)
F2.1 - Rule for “standalone arrow” updated to follow standard from 2022 (#HAN-5564)
F2.1 - The width of signs with “standalone arrow” was not updated before after edit (#HAN-5567)
F2.2 - The vertical position of RoadNo was not correct when multiple rows (#HAN-5652)
F2.3 - Removed the default text (PLUHTIKYLÄ) from the second line in plate two (#HAN-5751)
F10 - It was not supported to delete the NUMBER from the add on plate at the top (#HAN-5651)
F17 - Added support to used “Add plate” (#HAN-5665)
F18.1_2 - Added support to used sign as “mini” on other signs (#HAN-5526)
F18.2_2 - Added support to used sign as “mini” on other signs (#HAN-5527)
F18.3_2 - Added support to used sign as “mini” on other signs (#HAN-5528)
F18.4_2 - Added support to used sign as “mini” on other signs (#HAN-5529)
F19-F20.x - Used a wrong horizontal distance for RoadNo (#HAN-5690)
F19-F23 - It was not possible to add arrow F-CR_1 and F-CR_2 (#HAN-5648)
H19.x - Added support for both yellow and blue background (#HAN-5707)
G1 - The width of the border was not correct for colorfield (#HAN-5709)
G1 - The geometry for the border on colorfield was not correct in outline mode (#HAN-5710)
G5 - Buttons for “Road No” and “Mini” disabled (#HAN-5534)
Norwegian Version
New
3DSIGN - Added support for User Defined foundation for standard configuration (#HAN-5601)
Mini - Added a combination of 767 and 807.4 as a new mini symbol (#HAN-5583)
Fixed
3DSIGN - The value for “Type” was missing from the sign properties (#HAN-5672)
Swedish version
Fixed
F1-1 - Some combinations used a wrong distance from colorfield to border (#HAN-5616)
F8-2-4 - Used a wrong distance from text to border when two lines of text on the same row (#HAN-5617)
NOVAPOINT ROAD MARKING
Norwegian Version
Enhancements
RMTABLE - Added support for MilledMarking in table Mengdetabell_003 (#HAN-5687)
