DRAWING
For info related to Drawing go here.
Users who already installed Drawing 2023 will see this message when starting Drawing from Novapoint/Quadri.
Most functions will work as normal, but we recommend uninstalling Drawing 2023 and install the newer version.
QUADRI FOR WINDOWS
NOVAPOINT ROAD
Alignment Design
FIXED: In Drawing it would crash when changing radius from the commandline when in 'Angular Point'-mode.
Road Standard
NEW: Typical Cross-section dialog supports asymmetric cross-sections, defined pr surface group.
The dialog will automatically display Symmetric/Asymmetric depending on the data of the cross-section (surfaceno. in use, surfacename, width, slope)
Layer Properties
ENHANCEMENT/FIXED: Minor issues in the Pavement dialog and task.
Quantity report
ENHANCEMENT: Not all cases of overlap was reported in the Warning-tab.
Vehicle Tracking
FIXED: Drawing performance.
NOVAPOINT RAILWAY
Stakeout wizards in Quadri for Windows
ENHANCEMENT: Railway tasks are included in the selection.
NOVATRACK
FIXED: Minor issues when editing the alignment.
FIXED: Export to LandXML, minor issues not related to geometry.
NOVAPOINT WATER AND SEWER
Quadri - Utility
Design
NOVAPOINT BRIDGE
FIXED: For some models the Draw 3D functionality crashed.
NOVAPOINT TUNNEL
FIXED: For some models the tunnel base was not drawn correctly at the location of crossing tunnels.
FIXED: For some models the Distance Plan Drawing crashed.
NOVAPOINT ROAD SIGN
Finnish Version
New
The program has been updated with support for a number of the new signs launched by the Finnish Road Administration 01.06.2020 and updated in 2021 and 2022. The new version of the sign program can for a transitional period run in parallel with the version of the program that supports the previous standard.
Added support for new signs: - F10_8 - F10_8_2 - F10_8_3 - F10_8_4 - F10_8_5 - F11_6 - F11_6_2
3DSIGN - Added support for User Defined foundation for standard configuration.
Enhancements
General - Changed the look of border in “outline mode” for prof. signs (#HAN-5890)
General - Added support for black background color in “colorfield” (#HAN-5900)
TSTABLE - Added support for x,y,z coordinates for top on base for each mast in a 3DSIGN (#HAN-5842)
Fixed
TSTABLE - The values for X and Y coordinates in the table was swapped (#HAN-5889)
Mini - Combinations of F46.1x and F46.2x was missing (#HAN-5834)
F1.1 - Improved several rules for vertical and horizontal alignment of content
F10 - The total width of sign was not correct for some combinations if only arrow (#HAN-5898)
F16 - The user get a fatal error when try to insert mini and service (#HAN-5920)
F16 - Added all supported MINI and SERVICE (#HAN-5921)
F19 - TH40 is changed to TH45 (#HAN-5950)
F19 - Height of plate was not ok for TH45 (#HAN-5954)
F19 - Width of border was not ok for TH45 (#HAN-5955)
F19 - It was not ok to change TH for Eurovelo symbol (#HAN-5963)
F20.1 - TH40 is changed to TH45 (#HAN-5951)
F20.1 - Height of plate was not ok for TH45 (#HAN-5954)
F20.1 - Width of border was not ok for TH45 (#HAN-5955)
F20.1 - It was not ok to change TH for Eurovelo symbol (#HAN-5963)
F20.2 - TH40 is changed to TH45 (#HAN-5952)
F20.2 - Height of plate was not ok for TH45 (#HAN-5954)
F20.2 - Width of border was not ok for TH45 (#HAN-5955)
F20.2 - It was not ok to change TH for Eurovelo symbol (#HAN-5963)
F21.1 - Reduced TH for number after comma was not always correct for the distance NUMBER (#HAN-5973)
F22 - Reduced TH for number after comma was not always correct for the distance NUMBER (#HAN-5973)
F26 - Reduced TH for number after comma was not always correct for the distance NUMBER (#HAN-5973)
F26E - Reduced TH for number after comma was not always correct for the distance NUMBER (#HAN-5973)
G1 - The width of the border was not correct for colorfield (#HAN-5850)
G1 - The horizontal distance from symbol to border was not correct in all combinations (#HAN-5899)
G3 - The size of arrow was not correct for signs with only one line (#HAN-5897)
G5 - Plate height was wrong for multiple lines if TH=150 (#HAN-5894)
H1_2K - Some combinations was not ok if user change size after inserted to dwg (#HAN-5928)
H1_2-XL - Wrong color for NUMBER on blue and brown background (#HAN-5929)
H1_3-XL - Wrong color for NUMBER on blue and brown background (#HAN-5930)
Norwegian Version
New
3DSIGN - Added support for new mast type - SafeHit
Mini - Added support for 767_807.3 (Park and Ride) as new mini symbol (#HAN-5903)
Enhancements
TSTABLE - Added support to draw POS NO as text (currently BLOCK with attribute) in the table (#HAN-5854)
526.2 - Updated with data for size under sign properties (#HAN-5830)
560 - Added support for more mini symbols (#HAN-5857)
731 - Added support for more mini symbols (#HAN-5858)
Fixed
TSEXPLODE - Was not correct on brown background for sign 600.xx (#HAN-5860)
600 - A few symbols was not handled as a “brown” symbol for setting automatic brown background color (#HAN-5859)
753.2 - Horizontal alignment of arrow was not ok when only arrow as content on the line (#HAN-5642)
Swedish version
New
NOVAPOINT ROAD MARKING
Finnish Version
Enhancements
K5 - Updateed according to new design rules (#HAN-5646)
