Novapoint
NOVAPOINT 2023.2 Release Notes
05-09-2023 06:27
NOVAPOINT 2023.2
Release date: 09.05.2023
Quadri for Windows & Novapoint works with Windows 11
DRAWING
For info related to Drawing go here.
IMPROVED: Updated version of Drawing is available with this release. Version 4519.
QUADRI FOR WINDOWS
NOVAPOINT
IMPROVED: Support for Autodesk AutoCAD 2024.
NOVAPOINT ROAD
Typical cross-section definition
FIXED: Some cases of widening not being calculated correctly for user-defined typical cross-sections that are paired with widening calculation from a standard on the install.
Cross-section calculations
FIXED: Models with filtercourse could experience a filtercourse that didn't follow the bottom of superstructure properly.
3D production to Quadri
FIXED: Some cases of slow models due to overlapping sections in the design.
Vehicle Track Analysis
FIXED: Some vehicles could not be edited.
Quantity report
FIXED: Cases of crash when extracting the report.
Swedish market
CHANGED: Changed the length of vehicle Lspec
NOVAPOINT RAILWAY
Reports
FIXED: Report for Geometry_Railway_Alignment_By_Element is improved wrt gradient percent vs permil.
Norwegian market
NEW: Now supports Train cross-sections for new tracks.
Finnish market
IMPROVED: Importing Station Equations (KM) is now supported for Inframodel 4.0.4.
NOVATRACK
IMPROVED: New helpfile to guide users.
NOVAPOINT WATER AND SEWER
Design - vertical Drawing
  • IMPROVED: Trench slope behavior; In/Out diff setting in WS Config is now red as default value. See Video (Here) for more details.
  • IMPROVED: When changing slope from vertical window all inn/Out Diff is now kept for manholes. changing the slopes on only the pipe, as shown in video above.
  • UPDATED: (NOR users) GML - updated conversion rules for “Norsk Vann” schema 2.2 (prosjektering), GUID for Kumlokk “påKum”.
NOVAPOINT ROAD SIGN
Belgian Version
New
General - New function that scans the drawing for sign objects without a reference line
Finnish Version
New
The program has been updated with support for a number of the new signs launched by the Finnish Road Administration 01.06.2020 and updated in 2021 and 2022. The new version of the sign program can for a transitional period run in parallel with the version of the program that supports the previous standard.
Added support for new signs:
  • F1.3
Enhancements
General - Implemented a control in the dialogue that indicate if right click menu available or not (#HAN-6109)
F13 - Improved the horizontal alignment of content in some combinations (#HAN-5794)
F19 - Added support for Add Plate button (#HAN-6074)
F19 - Added support for delete mandatory symbol in front (#HAN-6113)
F20.1 - Added support for Add Plate button (#HAN-6075)
F20.1 - Added support for delete mandatory symbol in front (#HAN-6114)
F20.2 - Added support for Add Plate button (#HAN-6076)
F20.2 - Added support for delete mandatory symbol in front (#HAN-6115)
Fixed
General - The area of sign in dialogue was wrong if not all the plate got the same length (#HAN-6038)
C24 - Added support for numbers with comma (#HAN-6032)
F2.1 - The location of “mini” and “service” has been improved (#HAN-5565)
F2.1 - The vertical distance from road number to road number was not correct in all combinations (#HAN-6088)
F13 - The length of sign was not always correct when multiple plates in combination (#HAN-6078)
F13 - The horizontal alignment of road no was not always correct when two plates in combination (#HAN-6087)
F27.1 - Multiple line of text should be left aligned (#HAN-6160)
G1 - The minimum horizontal distance from symbol or text to border was not always correct (#HAN-6186)
G2 - The minimum vertical distance from arrow to border was not correct if only one line of content (#HAN-6081)
Norwegian Version
New
Enhancements
General - Implemented a control in the dialogue that indicate if right click menu available or not (#HAN-6016)
Road no - Implemented support for two-digit number in the Eurovelo symbol (#HAN-5918)
Fixed
707.2 - The sign was not working in Drawing (#HAN-6062)
727.4 - Added support for signs without indication of length for tunnel (#HAN-6098)
Swedish version
New
Enhancements
T1 - Added support for blue background (#HAN-6177)
NOVAPOINT ROAD MARKING
Danish Version
Enhancements
General - Added support in the DrawRefForLine function to name the line type in the drawing (#HAN-5911)
Norwegian Version
Enhancements
General - Added support in the DrawRefForLine function to name the line type in the drawing (#HAN-6143)
General - Added support for two missing arrows (#HAN-6137)
General - The line type Sykkelkryssing was defined twice with the same values (#HAN-6138)
RMTABLE - Improved the name used for a few object types (#HAN-6134)
