Novapoint
Novapoint 2023.3 Release Notes
06-28-2023 23:50
NOVAPOINT 2023.3
Release date: 28.06.2023
Click here for information about Known issues and Compatibility Breaks.
Quadri for Windows & Novapoint works with Windows 11
Release Notes for Novapoint 2023.3
Jump to:
Quadri for Windows
Novapoint CAD Tools
Novapoint Road
Novapoint Railway
Novapoint Water and Sewer
Novapoint Bridge
Novapoint Tunnel
Novapoint Road Sign
Novapoint Road Marking
Novapoint Land Use Planning
Novapoint Landscape
(CIVIL) DRAWING
For info related to (Civil) Drawing go here.
IMPROVED: Updated version of (Civil) Drawing is available with this release. Version 4520.
QUADRI FOR WINDOWS
NOVAPOINT
NEW: We have set up some new help pages for our customers which are available on novapointhelp.trimble.com.
The old help pages on help.novapoint.com will be discontinued during summer of 2023.
NOVAPOINT ROAD
Pavement
FIXED: Better handling of layers where the lowest course could take a shortcut.
Quantity report
IMPROVED: Road tasks with names containing special characters not supported in Microsoft filenames were not produced.
IMPROVED: Quantity reports has better handling of special cases when segmenting the quantities into intervals.
Draw to CAD
IMPROVED: Draw Roadmodel with block annotations was reverted to text every time. Now it will remember the previous choice.
NEW: New Element available for the configuration of Horizontal Alignment styles - “Vertical curve informations-SwitzerlandStyle”
It is similar to the “Vertical curve informations-FinlandStyle” that is already available for Horizontal Alignment styles.
NEW: New Element available for the configuration of Longitudinal Profile styles - “PVI-Info_04”. It is similar to the “Vertical curve informations-SwitzerlandStyle” that is available for Horizontal Alignment styles.
Market specific
Switzerland
NEW: Drawing style for Horizontal Alignment - “Switzerland”
NEW: Drawing style for Longitudinal Profile - “Switzerland.Road.Standard”
NEW: Drawing style for Cross-sections - “Switzerland.Road.Standard”
NOVAPOINT RAILWAY
FIXED: Issue where cant feature in Quadri did not have cant.
NOVAPOINT WATER AND SEWER
Quadri
  • NEW: Store userDefined ID also on manholeparts. Under GenericPropertyList you will now see under all manhole parts the property: “ConnectionUserDefinedID”
  • NEW: Export Task Template for LandXML
  • NEW: LandXML conversion rule “Trench Lowest Surface”
  • New: (NOR) IFC conversion rule “Stikningsdata og PSET”
Export from CAD menu - SOSI
  • IMPROVED: New input for CRS - added link to the right to table that shows what SOSI code user should write
Design - Vertical drawing
  • FIXED: Protection distance is now showing top pipe pressure pipe to terrain
  • FIXED: Interpolate between two nodes moved pipes in wrong direction
Design - Plan drawing
  • NEW: Added possibility to manually set connection angle (Bend) in graphic
Presentation - Plan drawing
  • FIXED: Draw Trench - lines drawn only if All lines were selected
NOVAPOINT ROAD SIGN
Danish Version
New
General - Added the command for FILL_SOLID_HATCH to the Ribbon menu (#HAN-6155)
Finnish Version
New
The program has been updated with support for a number of the new signs launched by the Finnish Road Administration 01.06.2020 and updated in 2021 and 2022. The new version of the sign program can for a transitional period run in parallel with the version of the program that supports the previous standard.
Added support for new signs:
  • F1.2
Enhancements
Road No - Improved the rules for TH=100 and TH=120 (#HAN-6312)
General - Added support for additional signs in TSINFO (#HAN-6284)
General - Added support for additional signs in TSTABLE (#HAN-6285)
F2.1 - Added support for move content by using right and left arrow inside colorfield (#HAN-6289)
G1 - Added support for additional signs (#HAN-6181)
Fixed
General - Not always correct color combinations for MINI on signs with yellow background (#HAN-6297)
F1.1 - Alignment of text was not ok when multiple rows (#HAN-6256)
F1.2 - Not using the correct distance from arrow to symbol (#HAN-6316)
F13 - Horizontal alignment of road no and number not always correct when two plates in combination (#HAN-6139)
F13 - Horizontal alignment of distance not correct when right arrow (#HAN-6366)
F13 - Removed the support for inserting F34x as road number (#HAN-6341)
F26 - Used wrong distance between multiple language rows (#HAN-6287)
G1 - The text should be left aligned if symbol in front of text (#HAN-6194)
G2 - One combination was not correct in outline mode when wipeout was enabled (#HAN-6077)
H3 - The size for default version of the sign was not correct (#HAN-6280)
Norwegian Version
Enhancements
312 - Updated the range of supported legal values (#HAN-6373)
600.xx - Added support for TH 280 and 315 (#HAN-6298)
Fixed
3DSIGN - Using the function “Draw 3D-sign” was crashing the application (#HAN-6326)
3DSIGN - User was in many combinations getting a FATAL ERROR when try to update sign combinations with pole type set to Lysmast (#HAN-6382)
NOVAPOINT TUNNEL
* FIXED: Cross-section drawing: The height value annotation for the railway reference line was wrong. This is now corrected.
TERRAIN
Market specific
Finland
RE-ADDED: Terrain module is available again.
