Novapoint
Novapoint and Quadri Archive
01-03-2021 19:27
ARCHIVE
Here we will put resolved issues from the known issues list that are older than one year.
For all changes see our Release Notes.
Date when noted
YYYY/MM/DD
From
version
Product Description Fixed in
version
2019/03/12 21.FP3 NP Road Drawing Longitudinal Profile to CAD from non-reserved tasks causes issues.
* AutoCAD crashes.
* Roadtask is not able to build afterwards, even after reservation.
Temporary solution 1 (recommended):
Extract the roadmodel via PARAM-file or roadmodel files and create a new task.
Temporary solution 2 (recommended): Disconnect the local dataset and download a fresh dataset. Reserve the task and continue with the work.
Temporary solution 3 (for advanced users): Requires reservation of the task (IMPORTANT).
- On your local dataset, find the project files and the roadmodel files for the task with the error.
- Delete the *.$$i-file.
- Check the read-only on the *.DMI-file.
- Release the read-only on the DMI-file by unchecking the checkbox.
NP21.FP3b
2019/02/14 21 NP Road Quantity report can show very large or small values if the boundary or boundary alignments start/end in the same chainage as the start/end chainage of the road model. NP21.FP3b
2019/02/12 21 NP Road Apply-button in dialogs or building cross-sections from the Cross-section Viewer will lead to crash when a 3D Presentation with transparency for the active road is in use.
Temporary solution: Close the 3D Presentation.
NP21.FP3b
2018/11/20 21 NP Road Combination of viewing 3D Presentation with transparency for the active road task being build may lead to a crash in some situations.
Temporary solution: Don't show the 3D Presentation when building the road task.
NP21.FP3: Partly fixed for NP21.FP3.
