Object Marker
04-12-2021 16:50
Object Marker
What
Here you govern the appearance of the object markers (satellites for manholes) in the plan drawing. This includes layer name in the drawing, layer color, line type, and color, with which font the name of the manhole is written, text height, text color, and the length of the line between the node and the satellite.
  • The object markers (satellites) are not drawn unless the check box “Draw Object Markers” is marked under Plan.
  • Line length and text height are valid for a scale of 1:1000. When making drawings in other scales, the proportions are adjusted accordingly.
Where
The function is run from the following locations:
