Novapoint GeoSuite Toolbox is delivered as a Windows installation package (msi). For normal client installation, the installation should always be started with Setup.exe for all related components to be checked and installed - see Standard client installation.
You can standardize a company-specific installation by running the installation with installation script. Below are some information and tips:
Dependent components
A scripted installation must ensure that a third-party CAD component “VectorDraw Lite File Converter” is installed. This is mandatory for Windows graphics to work properly in the applications. The installation package to run is in a folder under ISSetupPreerequisites. The installation file is called
vdFileConverter4.msi
In addition, there may be a requirement for Microsoft standard installation components specified for the current version.
Settings Template
During installation, a set of settings for the Novapoint GeoSuite Toolbox is added under ProgramData in the folders:
New users who log in to the computer receive a copy of these settings at 1st startup. It is therefore good if these templates are appropriately selected in the scripted installation.
Standard installation folder:
where 16 refers to the main version number of GeoSuite Toolbox.
GeoArkiv
GSGEOARKIVPATH=P:\GeoSuite\GeoArkiv\
In this folder, the GeoArkiv database must be located (Geoarkiv.bin). This database is / should be common to all users of GeoSuite Toolbox within the company. All users then have access to the same set of project databases.
Licensing
The license may be a local PC license (referred to as 1st launch of GeoSuite) or a floating license.
The license server name is specified after @. Use semicolon (;) as a separator if multiple servers should be used.
If Novapoint is installed on the same computer, the same license path is normally used, and this parameter can then be left blank.
Read more about installation and licenses here
The settings shown below are used in older versions to easily switch between two CAD platforms and associated Novapoint versions. This is now easier in Config Switcher for the Novapoint GeoSuite Toolbox in the application's program group.
AutoCAD
GSAUTOCADVERSION=R23.0 (main version for AutoCAD)
GSAUTOCADPATHA=C:\Program Files\Autodesk\AutoCAD 2019\acad.exe
GSAUTOCADPATHB=C:\Program Files\Autodesk\AutoCAD 2017\acad.exe
Exemple:
GSAUTOCADPATHA set to R23 for AutoCAD version 2019
GSAUTOCADPATHB set to R21 for AutoCAD version 2017
Novapoint
The settings to Novapoint for version 18.30 or lower is controlled by the NOVAPOINTVER and NOVAPOINTPATH parameters. These can be initiated in packing by setting the parameters GSNOVAPOINTVER and GSNOVAPOINTPATH.
Exemple Novapoint 18.30
Exemple Novapoint 19.20
ACADEXE should not be switched to NovapointBase.exe.
If you intend to retrieve data from Novapoint 19 - for example, to load road model or terrain model data into AutoCAD profile drawings - make sure AutoCAD is started via Novapoint.
