Novapoint Terrain Library
Pasteclip Point Elevations
04-12-2021 12:39
Use this tool to pasteclip point elevations and slopes to a new drawing which have been copied from another drawing by using the function Copyclip point elevations. Please note that the AutoCAD-command pasteclip' does not work on point elevations!
MOUS_ICO Menu: Terrain > Elevation label>
Pasteclip point elevations
MOUS_ICO Toolbar: Elevation label: Pasteclip point elevations
Working procedure
Start this function after the function Copyclip point elevations has been used in the drawing with the point elevations you want to copy to current drawing. The command prompts:
Select new position or type world coordinates:
Choose a position for the copied elevation object(s) or type the world coordinates.
About point elevations in Novapoint Terrain
  • The levelling tools are a set of functions working within the dwg-file as well as interacting with active terrain model. Editing and calculating point elevations must be done by using the levelling tools only. It does not work to use AutoCAD-functions like move, copy, copyclip/paste, properties, attribute editor etc. in order to edit or manage the appearence of the point elevations
