Use this tool to pasteclip point elevations and slopes to a new drawing which have been copied from another drawing by using the function Copyclip point elevations. Please note that the AutoCAD-command pasteclip' does not work on point elevations!
MOUS_ICO Menu: Terrain > Elevation label> Pasteclip point elevationsMOUS_ICO Toolbar: Elevation label: Pasteclip point elevations
Start this function after the function Copyclip point elevations has been used in the drawing with the point elevations you want to copy to current drawing. The command prompts:
Select new position or type world coordinates:
Choose a position for the copied elevation object(s) or type the world coordinates.
