Novapoint Road Library
Path by Arcs
04-19-2021 15:09
The function generates a path using arcs between the picked points.
  • If the radius of an arc is larger than the user defined value (Maximum Radius), the arc will be substituted with a line.
Run the function form the following locations:
MOUS_ICO Toolbar: Vehicle Track Analyzer - Make/Edit Path: Arc/Line
MOUS_ICO Menu: Road > Vehicle Track Analyzer > Make/Edit Path > Arc/Line…
