Trimble Penmap
Penmap for Android 11.9.0.2614 (last version for devices lower Android 7)
11-08-2024 04:42
Find attached the last version of Penmap for Android running on TDC100/TDC150 or other devices lower than Android 7
Install
To in stall the version on you device
  1. Download the zip file and extract it
  2. Connect your Android device to your PC
  3. Activate File Transfer on your Android device if it's not found directly
  4. Copy the "com.trimble.penmap-11.9.0.2614" e.g. to the download folder of your Android device
  5. Open a file explorer on your Android device
  6. Click on the file and follow the instructions to install
Improvements
  • Coordinate System Database update to version 108
  • The same WGS84 datum reference is used to store Autogenerated field values “latitude/longitude” in GIS data and export CSV data
Bug fixes
  • Fixed an issue storing a new user defined NTRIP caster at first time after installation
  • Fixed issue recreating data when automatic repair of project
  • Other minor improvements
#PenmapForAndroid
#TDC100
#TDC150
1 Files
4 Downloads
Attachment(s)
zip file
Penmap for Android 11.9.0.2614   77.31 MB   1 version
Uploaded - 11-08-2024
Zipped Penmap for Android installation file for devices lower Android 7
