Trimble Penmap
Penmap for Android - Beta DWG / DXF "export"
04-16-2019 08:25
We are happy to announce the release of a Beta DWG / DXF export in Penmap Project Manager as well as in Penmap for Android.
With this export you are able to convert a Penmap project, which is uploaded to Trimble Connect, into a DWG or DXF file.
Beside the pure conversion you have the possibility to "export" new and modified data only to a DWG / DXF file. As Penmap is able to track the status (old, new, changed) of features and graphics in the database we are able to export only new and changed data to DWG / DXF. We can not track deleted data as there is not possibility to mark data as deleted in DWG / DXF.
In Penmap for Android you can decide if you want to convert the project to DWG / DXF only or also download the file to the Android device.
Format´s
  • The DWG file will be exported in AutoCAD DWG file format 2018
  • The DXF file will be exported in AutoCAD DXF file format 2014
  • Open a Trimble Connect project in Penmap Project Manager
  • Select a Penmap project which is "Completed"
  • Press the download button and select the file format and settings
Penmap for Android
  • Upload the project to Trimble Connect so that the project is in sync with the cloud
  • Tap&Hold the Penmap project and select export
  • Select the format and settings for you export and press the export button
Feedback
Please let us know how the DWG / DXF project conversion works for you.
Send us a message to penmap@trimble.com
02-12-2023 18:29
Hi Martin,
A .dwg file (2018) created by Turbo Cad could not be read properly by Trimble Penmap. Could you please advise
04-16-2019 09:12
Hi Matt, good point I did not clearly pointed out. You do not need a new Penmap for Android version or a new Penmap Project Manager version. As we made this change available "in the cloud", the current released versions have this functionality.
Best regards, Martin
04-16-2019 09:06
Is there a location where the latest Beta of Penmap for Android and Beta Penmap Project Manager can be downloaded for use? The Google Play Store is still at release 10.8.5 here in the US.
Thank you,
Matt
Matt bombace
Utility Group Modeler
411 N. Roosevelt Avenue | Chandler, AZ 85226
o: 602.875.8749 | c: 480.737.1758
www.connect202partners.com<http://www.connect202partners.com/>
www.southmountainfreeway.com<http://www.southmountainfreeway.com/>
