Pipe connections to longitudinal profile
07-16-2021 05:27
What
This function adds pipe connections to a drawn longitudinal profile.
Where
You find the function in the following location:
How
The following method is used:
  1. Start the function
  2. The dialogue "Select traces appear"
  3. Select trenches with pipes that cross. ctrl + leftclick two or more trenches
  4. End with OK
  5. Command prompts for "Select profile frame to draw to:"
  6. Select the frame of the longitudinal drawing
  7. The pipe connections will appear in the longitudinal drawing
