Pipe Materials
What
Use this function for registering new pipe materials and new dimensions, either by adding new materials or by copying and editing existing or to delete material types or dimensions you do not want to keep anymore.
Where
The function is run from the following locations:
How
New material is used to add new materials. The function is run from the following locations:
Copy material is used for registering new material types by copying and editing already existing types. The function is run from the following locations:
Materials that are no longer needed in the WS project, may be deleted. Delete material is run from the following locations:
New pipe materials are to be given names, abbreviations, and dimension types in the sections in the right pane of the dialogue. Further, there is stated whether the pipe dimension is described by its inner or outer diameter. This dialogue is also used for editing the span of dimensions for the different material types.
Add new dimensions by using the function New Dimension, run from the following location:
After that, key in the desired diameter, class, and wall thickness.
Remove dimensions by using the function Remove Dimension, run from the following location:
