Plan
04-12-2021 16:53
Plan
What
This dialogue includes the following settings concerning the appearance of the plan drawing:
  • Symbol paths: This controls where the program fetches symbols for the drawing. Here the user may insert folders with self-defined symbols.
  • Node Flag Position: Indicates how much the node marker may be moved and not move back to its original position when the plan is redrawn.
  • Pipe text position: Indicates how much the pipe text may be moved and not move back to its original position when the plan is redrawn.
  • Pipe Extra Offset: Default the pipes are drawn with 1,0 m offset in the drawing. If a larger offset is desired, enter increase here. Extra offset is valid for scale 1:1000 and is changed according to scale in other scales.
  • Draw Deleted Pipe Text: This checkbox should be marked if you want pipe text being deleted during the editing of the drawing to be drawn if the plan drawing is redrawn.
  • Draw Manhole Markers: This checkbox should be marked if you want manhole markers to be drawn in the plan drawing.
  • Draw Node Markers: This check box should be marked if you want node markers to be drawn in the plan drawing. You will probably not want to draw markers for both nodes and manholes. This may look somewhat messy.
  • Use Leader Marker: This check box should be marked if you want leader markers for angular points to be drawn in the plan drawing. The function marks all angular points, not just the ones outside the nodes.
  • Draw Elev Markers: If this check box is marked, there will be written out elevations for pipes both in and out for all manholes, together with coordinates for the manholes. See also Elevation Marker and Elevation Marker Prefix
  • Draw Trench Markings: If you want to draw chainage for the trenches, this check box should be marked.
  • Trim Pipes at Manholes: If this check box is not marked, the pipes are drawn continuously through the manholes.
  • Adjust Point Rotation with Pipes.
Where
The function is run from the following locations:
