Plan and Profile
04-12-2021 16:18
What
Use this function to generate a plan and longitudinal profiles for the corresponding plan.
  • Plan and respective profiles will be generated on a section basis of 750.0m for a drawing scale of 1:1000. For other scales, the section length varies.
  • The function clips and pastes together parts of plans and corresponding longitudinal profiles.
  • The function is based on the AutoCAD commands “Model space” and “Paper space”.
  • For a detailed description of Model space and Paper space, see AutoCAD help.
The minimum requirements before executing the function are as follows:
  • Draw the plan of the Water and Sewer project using the function “Plan”.
  • Draw plan frames to the plan using the function Insert Frame/Panel of the menu Novapoint Drawing Layouts.
  • For a detailed description of generating plan frames, refer to the topic Insert Frame/Panel.
  • The frame to be used for this function is Half height A1.
  • The length of the frame/panel depends on the “Drawing Scale”.
  • Plan frames are to be drawn all along the trench length, for which plan and profiles are to be generated.
  • The frames should be oriented such that they are parallel to the trench. Orientation can be done using AutoCAD's “Rotate”, “Move”, etc., functions.
  • Draw the profile frames using the function “Longitudinal Profile”.
Where
Run the function “Plan and Profile” from the following location:
How
  1. Command prompts for:
    Select Plan Frame:
  2. Select the Plan's Red Frame.
    Enter Plan View Name:
  3. Define a name for the selected plan view to identify it.
    Select Profile Frame:
  4. Select the Profile frame corresponding to the section of the plan frame selected.
    Enter Profile Frame Name:
  5. Define a name for the Profile frame selected, to identify it.
The next step is to go to AutoCAD's tab Layout and run the function Plan and Profile again.
  • Before going to the tab Layout, repeat the function on AutoCAD's Model tab so that all the plan frames and profile frames are selected.
  • When all the plan frames covering the whole section of the trench and related profile frames are selected, switch to the tab Layout.
  • Define the plot settings.
  • Run the function Plan and Profile.
  • The dialogue box Select View will pop up. This includes a list of all the plan views and profiles views.
  • Select the plan view to be added to the layout and click OK.
  • Again the same dialogue box will pop up.
  • This time select the respective profile view.
