Plan Cable
07-16-2021 02:28
Plan Cable
What
The cable configuration displays pipes and manholes very much alike the WS configuration. The difference is the symbols and details. Plan cable displays the actual size of the manhole, where plan WS displays the manhole defined in the configuration.
To edit drawing style, go to Cable and WS Plan Style
Where
You can start the function in the following location:
How
When you start the function, the following window will appear:
  1. Select the trenches to display
  2. Select rotation
  3. Choose between geometry or symbol for the manhole display
  4. Choose drawing style
  5. End with draw
  6. Use the drawing editor to edit the drawing
