Novapoint Terrain Library
Point Elevation from Terrain
04-12-2021 12:53
This function calculates the elevation (z-value) from the active database/terrain model in the current point position and writes it in the drawing.
MOUS_ICO Menu: Terrain > Elevation tools >
Point elevation from terrain…
MOUS_ICO Toolbar: > Elevation tools > Point elevation from terrain…
Pick positions in drawing - the elevations will be set according to the active terrain model.
About point elevations in Novapoint Terrain
  • Point elevations are blocks with the insertion point in the “+”-sign. The z-value for the block will always be equal to the written text.
  • The leveling tools are a set of functions working within the dwg file as well as interacting with the active terrain model. Editing and calculating point elevations must be done by using the leveling tools only. It does not work to use AutoCAD-functions like move, copy, copyclip/paste, properties, attribute editor, etc. in order to edit or manage the appearance of the point elevations
