Novapoint Terrain Library
Point Elevation from Triangle
04-12-2021 12:54
Use this function to calculate the elevation of the desired point from the elevations of the triangle model (TIN model) available in the current drawing.
  • The calculated elevation will be inserted (on the current layer) as a text entity at that point.
  • Settings for text height and accuracy are to be defined on the command line.
  • Any number of points can be selected one by one for elevation values.
  • The minimum requirement for this function is that the triangle model is generated and drawn as '3D Face' to the current drawing.
MOUS_ICO Menu: Terrain > Elevation tools > Point elevation from triangle…
Working procedure
Command prompts for:
Height of text <5.0>:
Define the text height (meter).
Number of decimals <3>:
Define the number of decimal.
Single points or Points=blocks/texts [Single/Point] <Point>:
Points can be picked using the option 'Single' or blocks/text entities can be selected using the option 'Point'.
For the option 'Single (S)' command prompts for:
Select point:
Select the point, of which elevation is to be calculated from the triangle surfaces. The calculated elevation will be displayed on the command line and inserted in the drawing.
Z=526.498
Select point:
Continue to pick points in the drawing, or finish with the right button of the mouse or the key 'Return'.
…. UNDO [Yes/No] <No>:
Use to option 'Yes' to erase all the text entities inserted.
Use to option 'No' to retain all the text entities and exit the function.
For the option 'Points (P)' command prompts for:
Points = blocks/texts…
Select objects:
Select the objects (blocks and/or text entities), for which elevations are to be calculated from the triangle surfaces.
Selection modes of AutoCAD can be used for multiple selections.
Select objects:
Continue to select the objects or confirm the selection using the right button of the mouse or the key 'Return'.
The elevations will be calculated at the insertion point of the selected objects (blocks and text entities).
The calculated elevations will be displayed on the command line and inserted into the drawing. Example:
Z=526.795
Z=527.385
Z=527.336
Z=526.953
Z=526.587
Z=526.807
Z=527.027
