Use this tool to generate point elevations from triangles in a drawing.
MOUS_ICO Menu: Landscape > Levelling tools >Point elevation from triangle
Use triangles represented by 3D faces in dwg to calculate height and create point elevation. The visual style in the drawing must be of the type with shade in order to get point elevations with this function. (Use the command SHADE)
