Novapoint Terrain Library
Point Elevations from Terrain (grid)...
04-12-2021 12:57
Use this tool to get point elevations in a grid, from the active terrain model.
MOUS_ICO Menu: Terrain > Elevation tools >
Point elevations from terrain (grid)…
MOUS_ICO Toolbar: > Elevation tools > Point elevations from terrain (grid)…
Working procedure
  • Start the function.
  • Select line objects [lines, polylines, 3D polylines, circles, arcs,..] The objects must have intersections ar apparent intersections with each other in order for the function to work.
  • Point elevations will be generated from the active terrain model in positions where selected line objects are crossed [Intersection, Apparent intersection].
About point elevations in Novapoint Terrain
  • Point elevations are blocks with the insertion point in the “+”-sign. The z-value for the block will always be equal to the written text.
  • The leveling tools are a set of functions working within the dwg file as well as interacting with the active terrain model. Editing and calculating point elevations must be done by using the leveling tools only. It does not work to use AutoCAD-functions like move, copy, copyclip/paste, properties, attribute editor, etc. in order to edit or manage the appearance of the point elevations
