View Entry
Back to Library
FAQ - Position number is only in 00(zero)
Recommend
06-28-2021 01:59
Eirik Braaten
POS number is only in 00(zero)
When drawing out position number all the numbers are set to zero.
Solution:
In AutoCAD go to options and profiles. Find out which profile is active, then activate another profile.
Then delete the previously active profile (NB! If you have customized your toolbar it will be reset to standard configuration).
Restart AutoCAD and Novapoint, go into AutoCAD options and activate the previously deleted profile.
Now, it works again.
