Part 5 -Product library
06-28-2021 02:20
Here you can choose products and position 3D-models from a range of suppliers.
Where
You can find the product library in the Novapoint ribbon.
How
To use the Product Library you must choose the library you would like to use, download it and choose path (For further information see How to install the Novapoint Product Library ). When this is done, click “Product library” and the function will start.
In the product library you can choose between suppliers and their product. To place products into the project:
  • Click on preferred location and turn the model
  • Enter preferred coordinates and angle
  • A combination of the above
Product library window
Card index
Here you can browse between all the available products. Updates comes regularly with new products, so we recommend to follow our newsletter and we will keep you updated.
Illustration window
In the illustration window you can preview the part.
Insert/replace
Use insert whenever you want to place a new object into the project.
Use replace whenever you want to replace a object with a new object.
Filter
Filter out product. Write an attribute to only see desired product. For example, “concrete” to only get products made of concrete.
Reset filter
Will reset the filter
Node-snap
Assemble objects by choosing existing node.
Right tabs
Her you can choose between different suppliers.
Information table
Her you can find information about the products. To get more information about the product you can click on “product catalogue”.
