Product library properties
06-28-2021 02:29
Use this function to change or add the information on a product. You can change any of the attributes.
Note: Information you change or add will only be connected to single objects. Added information will follow the object if you copy it.
Where
You find the function in the Product library tab.
How
You use the function the following way:
  1. Start the function by clicking on the function.
  2. To see information on the object click on the object you want to change or add information to.
  3. You can see existing properties in the pop-up window.
  4. Click on the value tabs to change information.
  5. Click update to save information to an object.
Now, the product will contain the new information.
