Product Update - 08-27-2021 | All Connect for Windows installations must be updated due to the upgraded Trimble Identity
08-26-2021 23:49
Trimble Connect for Windows installations older than version 1.12.0 will be force updated to the latest version on Aug 31, 2021
The new upgraded Trimble Identity system will become effective on September 1st, and the change applies also to Trimble Connect. All Trimble Connect for Windows application installations older than 1.12.0 must be updated to continue using the application.
Due to the above reason, all Trimble Connect for Windows application installations older than version 1.12.0 will be force updated to the latest version on August 31st, 2021. After the forced update is applied, it won’t be possible to run the impacted Connect for Windows application versions anymore. Instead, the application will require downloading and installing the latest version before being able to continue.
Learn more about the benefits of the upgraded Trimble Identity here. Also check out the Sign In & Security help.
Release notes for the latest version: Trimble Connect for Windows version 1.12.2.
#Trimble_Connect_Windows
08-30-2021 05:07
@Scott Edgar Hello Scott, please refer to the Trimble Connect for Hololens release notes
Best regards,
Jari
08-30-2021 03:15
Please clarify how users can work offline with Connect for Hololens 2.  I can't seem to find any description of this workflow using the new Trimble Identity login.
