MOUS_ICO Models > Select Model > Modify > Projects > Projects Tab
The projects menu lists all the projects in the selected model. It is still recommended to have only one project in each model.
If you click the arrow button and select Users, you will get a list of all the users that have access to the project.
Click the Add button to add a project to the selected model and a wizard will be started:
Click the project name link and a wizard similar to the one used when the project was created will start. Go through the wizard and change what you need. Click Finish in the last step to save your changes.
Check the project and click Remove to mark a project as removed from the model. If there are no worksets downloaded from the project, the project is removed permanently. If one or more worksets exist, but none of them have reservations, the project will be marked as removed and not be accessible to the users any more. If a workset has reservations in the project, the user must first release the reservations before the project can be removed. It is also possible to remove a project in Novapoint.
Check the project and click Restore if you want to restore a removed project.
