QUADRI 2020.FP1
International Version
General
NEW: Property Set Editor. Possibility to add and edit user defined properties.
![](http://help.civil.trimble.com/lib/exe/fetch.php?w=700&tok=0d65fc&media=en:np:release_notes:quadri2020:quadri2020fp1:pset_editor.png)
FIXED: Problems with uploading to support
ENHANCEMENT: New Process Info pane, with many filtering options. You can drag columns to the header, then right-click for filtering options:
![](http://help.civil.trimble.com/lib/exe/fetch.php?media=en:np:release_notes:quadri2020:quadri2020fp1:processinfo2.png)
Export
NEW: Export for format DSZ (SVL/SVD). This file format is used in Trimble Business Center.
FIXED: Exports from Quadri not according to BuildingSmart standard.
FIXED: Handling of norwegian letters (æ, ø, å) for Generic attributes propertyname in IFC.
FIXED: Export of rail alignments gets strange AlignmentName in XML.
FIXED: LandXML stakeout to Leica 3D Visual Digger. Leica compatible irregular lines file.
ENHANCEMENT: Add support for material name in IFC export.
ENHANCEMENT: Support for Field Codes also for 4 and 4×1.
ENHANCEMENT: Associations to string in IFC Feature converter. Before convert association to string only supported feature ID.
Import
FIXED: Bug in geolocation for IFC.
FIXED: Import of DWG with multiple Arcs.
FIXED: Import of AGS-files. All coordinates should now be imported.
FIXED: Bug with Regular Expression in Extract value.
FIXED: GEN creating blank linetask names.
FIXED: Add Project rules to selection of preview drawing rules when importing.
ENHANCEMENT: Added support for AEC_Mass_Element in DWG import.
ENHANCEMENT: When importing DWG with texts that small rotations, the text now has the same size.
ENHANCEMENT: Conversion rule (“IFC2x3_Proxy with all attributes”) added for IFC imports for batch importing nameValuePairList as genericProperty.
ENHANCEMENT: Now possible to add regular expressions in Attribute to Attribute mapping.
![](http://help.civil.trimble.com/lib/exe/fetch.php?w=1000&tok=dd8180&media=en:np:release_notes:quadri2020:quadri2020fp1:a2a_mapping.png)
Modelling
NEW: Function for Delete Features Outside AOI. Click the function to see everything outside Area of interest, and delete if thats needed.
![](http://help.civil.trimble.com/lib/exe/fetch.php?media=en:np:release_notes:quadri2020:quadri2020fp1:aoi.png)
Presentations
FIXED: Versioning in WMS. Changed request from 1.1.1 to 1.3.0. Will now support servers that were problematic in prevous version.
Publish DWG
FIXED: Bug when publishing DWG using a Project Rule. Now it draws out with correct Drawing Rule.
FIXED: Bug when publishing DWG using Default Drawing Rule, making the process crash.
Norwegian version
